| Isx Cm870 fuel Actuator - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: Isx Cm870 fuel Actuator (/showthread.php?tid=10263) |
Isx Cm870 fuel Actuator - Another Dumb Farmer - 08-13-2025 Hey I’ve got a 2007 Isx CM870 that need fuel actuators and i can get some off of a QSX from a tractor but the part number are a little different do you think they would work or is this just asking for issues. Thanks My Isx part numbers Metering actuator: 4902906 Timing actuator: 4902907 QSX part number: Metering actuator: 4902904 Timing actuator: 4902905 RE: Isx Cm870 fuel Actuator - Rawze - 08-14-2025 Depending on how different they may be, you very well may end up with the wrong injection timing and/or the wrong fuel flows... making the engine end up with a significantly shorter lifespan. Just do the right thing and buy the correct OEM parts.. and stop trying to jump over a dollar to save a dime. |
