CM570 ECM - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: CM570 ECM (/showthread.php?tid=10099) |
CM570 ECM - TerryB - 04-28-2025 Can the ECM on this engine cause a dead cylinder? I have a CM570 with #3-cylinder dead. I replaced that injector and it's still dead. I pulled the injector again and inspected the cylinder with a bore scope. I don't see anything wrong to cause a dead cylinder. I'm going to swap holes with an injector to see if the problem follows the injector. I'm not sure if the ECM can cause an individual cylinder to fail? RE: CM570 ECM - Rawze - 04-28-2025 swap holes. |
