| Low boost x15 was 30-35 now peaks at 29 - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Low boost x15 was 30-35 now peaks at 29 (/showthread.php?tid=10795) Pages: 1 2 |
RE: Low boost x15 was 30-35 now peaks at 29 - marek4792 - 10-27-2026 You could be dealing with leaking exhaust manifold gaskets, warped/cracked manifold, EGR system pipes joints, ETC... Especially with the smell... On the X15's the burn so clean makes it a PITA to pinpoint without the soot trail showing itself, unless you cold start and spray everything down with soapy water... |
